UK 20000 PD + Nano bundled discount £39
This one is a little complex but works out a reasonable deal combined.
This 20000 PD is not particularly discounted currently at £30
But if you look at the promotion you see there’s 50% off the Nano bringing it down to £9 which would.make it the lowest cost ever.
Combined cost is
It’s also worth trying the discount codes, here there are two, on different combinations of Anker products ,as it says eligible items which could be something other than, in this case, a 20000 and Nano, and see if works.
I find if you look for something not discounted at all, like the Nano currently, it tends to work. So as this discount is 50% seek a high cost item you do want which is not discounted.
As these bundles seem to be occurring more often, store up a need for 2 items and see if pasting in the codes works.
Good advice @professor
Tricky but good that you mentioned how to navigate through.
Good deal on the nano, and potential to get really good deal on other items.
Thanks @professor
