Everything of this top speaker needs a bit of time to get really used to it.
Sorry, so it took me a while to write the review.
But first (online tracking): Damage to the package caused DHL.
This can happen.
I called all “supports” (ANKER, AMAZON and DHL)
to prevent any problems.
Really nice people!
(I am also a friendly person! )
Absolutely perfect, not the usual “service desert”.
Conclusion: If there is damage to the item detected by DHL during repackaging,
the parcel would NOT be shipped anymore and it would get an insured event.
But the ZERO arrived at last perfectly.
The original packaging from ANKER is very stable.
But let’s go to the device now:
I like good “design”.
So I also love the shape and the feel of this speaker.
It is bigger than the usual small “cans” and “bricks”.
Really a little “sound case”
But a real gem and eye candy, without any exaggeration.
The workmanship is excellent and very valuable.
Although I will use the ZERO more in the living area,
the speaker is ipx5 water protected.
But honestly:
For absolute, fast mobile use (pack in your bag or bag pack)
I would recommend a soundcore FLARE e.g…
Regarding the size and weight of the Zero : (1.9 kg).
(See photo in comparison)
The FLARE has also a built-in “light organ”.
This might be great fun for young party people!
I gave away the B+se mini and now my favourite speaker for traveling is the Flare
Let us take a look, better let’s listen to the most important thing
of a speaker:
The “sound”.
Again, this ZERO needs a while to get used to it.
The description says it is “Hi-Res Audio Certified” and using “Transducers Designed by SCANSPEAK”.
Result : Exact treble!
This may sound “overdone”(harsh) for some ears.
There are discussions about at some YT reviews.
But we have this bass button integrated: BASSUP ™ TECHNOLOGY
You should play around with a lot.
I always mentioned:
With a good equalizer, every speaker can be more or less
adjusted to the individual hearing.
Please do this, before leaving a “statement”.
At first, I took the heights back slightly.
But now I lift the heights successively day by day.
So I get used to it and the sound is “getting better” for my old ears.
It really takes some time to get the right feeling.
You might use the Soundcore application to play around with.
I don’t, the “equalizer” is really not my “taste”
For me an equalizer with at least 10 frequency ranges is absolutely a MUST.
Regarding the ZERO: The centers can be left as they are.
Only with the bass in the range of 30 to 130 Hz and the treble in the range of 3 to 8 Khz you might do some adjustments.
And as always said, PLEASE leave the preamp, if it is adjustable in your equalizer, in the minus range!
And last not least do not forget, speakers need some certain days “to warm up”.
The more you listen, the more you like!
Voluminous, overwhelming.
A mighty speaker!
It’s the best speaker I ever had.
Congrats Soundcore!
Getting better and better!
MY AND YOUR FLAGSHIP!
Addendum :
There is a “power indicator” next to the ON/OFF button.
After a while it starts blinking.
But what is the reason?
The manual doesn’t tell.
The charging status is shown by a little LED near
the charging socket at the back.
(last photos)
Addendum :
The Zero was playing 9:00 hours.
The LED started blinking after 8:30 hours.
So it took 30 minutes to shut down.
Charging takes 1:30 hours.
