Speaker Pairing
Hi,
I’ve got a Soundcore Motion B speaker and was wondering if it possible to pair it with the new Soundcore 2 speaker. Has anyone been able to do this? The documentation I have seen online does not make this clear.
Thanks
You can not pair two different speakers together natively. If you have an android phone with BT 5.0 your phone may support connecting to two different BT audio devices.
Good luck!
Definitely not.
Thanks, back to Amazon it goes :slight_smile:
@smittyuk
It is possible to pair the Flare and Flare+ together.
Yes, this should work, same hardware.
Does work :wink: :grin:
