My soundcore pro suddenly started a weird behavior where it continually looses bluetooth connections randomly just after connecting or sometimes it connects fine and loosing connections just after pressing the play button in my music player.
Soundcore pro disconnects while starting music
Try deleting the connection and then re-pair it. Also, make sure it’s not trying to connect to some other device that you may have paired it to.
