Disclaimer: This review was written as part of the We Love Testing program here.
Product Links
Key Features
- Two 40kHz ultra-high frequency tweeters, neodymium woofers and passive radiators for 30W of Hi-Resolution audio output
- Qualcomm aptX for improved bitrate and audio of lossless tracks
- Built-in & App controls for Power (On/Off), Play/Pause, Vol Up/Down, Bluetooth & BassUP control
- 6700 mAh Battery for up to 12hrs playback depending on volume level & content type
- Bluetooth 5.0
- 3-4hr charge time from USB-C charging port (USB-A to USB-C cable included)
- Built in microphone for hand free calls
- Auxiliary input (cable included)
- Wireless Stereo capabilities with pairing to another SoundCore Motion+
- IPX7 Waterproof rating - spray, splash or drown for up to 30 minutes at 1m maximum depth
The Impressive
- Very good audio definition over several genres tested
- USB-C charging port, backing those after a single cable solution
- Battery life that seems to go on and on, for the loudness it was at…
- App control with power control, including remote power down
- Customisable equaliser via the SoundCore App
- Ability to pair with another Motion+ for increased volume and/or wider stereo playback
- Water resistance - good for life accidents or your need to torture a speaker
Slightly Disappointing
- Low battery warning alert has been removed, not certain why….so playback of favourite albums come to a dead end…literally…
