I made the mistake of unpairing my speaker from my phone. Now my phone doesn’t see it at all. Does anyone know how to fix this?
Note: this is a phone issue, but I’m hoping someone here knows how to fix this.
Hi @jpritchett1 , check no previous pair records for the Motion B are present on your phones BT menu, if they are delete. Reboot your phone and try a fresh pairing of the speaker.
How do I do that? All I’ve been able to find is the current list. My speaker is no longer on it.
Thank you.
So your speaker is not listed so that is a good start…try a restart of your phone then see if the speaker shows in your BT menu when trying a fresh pairing…pressing the BT button on the Motion B for 2 seconds should force the speaker into pairing mode, which can on occasion force a prompt on your phone for speaker to be paired (as long as BT is enabled on your phone and searching)…
Have you tried “forgetting” the device from settings?
I tried that before. I tried it again after a shutdown. Still doesn’t find the speaker.
I haven’t found anything in settings that lets me do that.
This may be an Oreo problem.
Ok, problem solved. Perhaps it was a speaker problem after all. I asked my son to try to pair his Galaxy S9 with the Soundcore Motion B. After he did that, I was able to pair my S8+ with it again.
Thank you.
