Soundcore (an Anker company) has a new set of higher end truly wireless earbuds with the Soundcore LIberty Pro 2. These are an upmarket product for Soundcore, and feature a balanced armature and a dynamic driver. They feature a neat case and pretty impressive battery life in my testing. Thanks to Soundcore for sending these too me to review and tell you guys about.
YouTube Version of this Review: https://youtu.be/3AqCAjR1zts
Packaging & Accessories
Soundcore products have always had nice packaging but the Liberty Pro 2’s is above and beyond. It’s clear to me this package was designed with retail stores in mind. It’s textured in places and has a sharp eye catching design and lots of useful information to the consumer on the outside with all the stats and big features of the headphones. It’s a magnetic latch box so the consumer can look inside as well. Accessories include 3 sizes of ear wings, to help the fit in your ear, and then 3 sizes of each ear tip with duplicates of each. You also get a USB-A to USB-C cable for recharging the storage case.
Construction
The Soundcore case is vital to the operation of these headphones as it’s how you recharge the headphones. It’s made of a soft touch plastic and the door on the top has an addictive slide mechanism. If you like to fidget with things you will find yourself sliding this back and forth. The case itself allows the headphones to turn on and off via magnetic retention. As far as recharging the case has USB-C on the back, and is able to charge on a horizontal QI charging pad. You have 3 LED’s on the front that give you the battery status of the case.
Battery life of the LIberty Pro 2’s is good, Anker rates it at 8 hours and at least in my testing that’s pretty accurate. I recently took these on a business trip this week and wore them for hours at a time through airports and never had them get close to 50% and even if they do get low a 10 minute recharge in the case gives you an impressive 2 hours of additional playback time. Overall the 500mAh battery in the case is good for 32 hours of playback time. Size wise the case is a little on the large size for me. In my front jeans pocket it worked but if I was in shorts or had smaller pockets I could see it being a little too big. Other brands have more compact solutions if that’s an important factor for you.
Sound Quality Comfort & Software
Soundcore has developed their own set of drivers for the Liberty Pro 2’s called the Astria Coaxial Acoustic Architecture… For the mid’s and high they a custom developed Knowles (Well known in the audio industry) balanced armature combined with an 11mm dynamic driver for the lows. These are placed inside each other allowing for the sound to not have to be routed within the body of the headphones so that you have the best possible sound quality. This is a somewhat unique design that your not seeing on a ton of true wireless ear buds right not.
Soundcore has then teamed up with 10 “Grammy Award Winning” audio producers to further tune and refine the sound profile of these headphones. Combine this with the soundcore app on your Android or Apple device and you have a choice of several audio profiles for your specific type of music. The app also has a customized hearing test where it analyzes each of your ears ability to hear a range of frequencies and builds a profile for you. See the video for how this works.
So what’s my experience with these? Well as with any in ear headphone fit is key to sound quality, and I took my time here to find what works best for me, a balance of comfort, sound quality, and retention. I settled with medium sized ear wings, and small ear tips. Comfort was pretty good with this combo and fatigue after 5 hours straight was minimal. Retention was great, and I had no problem at the gym working on AMT’s and other machines, and I would feel comfortable running with these as well.
Sound quality was impressive for a wireless headphone. Your music source is very important here, heavily compressed music, such as most streaming services you might not notice a difference, but I had some lossless files on my phone and on these I could tell the larger sound stage, clarity and accuracy. Bass was pretty good as well, with it being almost too powerful on some of the presets. So if you like Rap or EDM these should work pretty well for you at this price point. These do feature Bluetooth 5 asd aptX which both improve sound quality.
One disappointing thing is at this price point there is no audio passthrough which means for conversations you have to pause your audio and take out an ear bud to talk to someone. This proved a little frustrating in an airport until I reprogrammed the button on the top of the headphone to allow me to pause my audio.
These do feature Qualcomm’s cVc 8.0 noise reduction technology when making calls, combine that with a total of 4 microphones and at least in my experience call quality was surprisingly good. I have read some other reviews that not everyone had the same experience I had. This is a feature I rarely use because who makes calls anyways.
Pro’s
- Great Sound Quality
- Long Battery Life
- USB-C and Wireless recharging
- Built in Sound profiles are good and make a difference in audio quality.
Con’s
- The earbuds themselves are a little big but retention is good for me
- Case is on the larger side
- IPX4 Water rated, while enough for sweat
- No passthrough audio for conversations and you must use both earbuds at the same time.
Conclusion
For me these are by far my best pair of wireless headphones, especially earbud style ones. Sound quality wise they live up to their price point for me. Bass was impressive, while still maintaining crisp mids and highs. Music quality matters here more than most normal headphones. You might not notice the difference on your average streaming service. I was impressed with the battery life here as well, of the headphones themselves and the case. Not many people are going to be listening for 8 continuous hours, and even if you are 10 minutes in the case gives the headphones 2 hours of use. In my travels this week I never came close to needing to recharge.
These only have minor disappointments, for me the lack of passthrough audio was unfortunate at this price point as well as these are just a little big. They are not something I want to lay down with if you are laying on your side.
All this said these get a solid recommend from me if you’re looking for a more high end sound, and a premium wireless ear bud for most situations to work with all your devices.
Full image gallery at: https://imgur.com/a/7pH27eM
