At $99, the Soundcore Infini Soundbar is an impressive 35" wide, sleek-looking tuned port soundbar supporting 2.1 Channel-like sound and Bluetooth. Comes with an IR remote control, two AAA batteries, optical cable, 1/8" stereo mini to RCA stereo cable, power cord, wall mounting hardware & template and a User Manual in 13 languages.
Setup was easy. Connect the power cord, connect either audio cable (optical or stereo audio cable) to your TV’s optical or stereo audio input (there’s a coaxial input on the soundbar but a coaxial cable is not included) and power ON the soundbar. Then with the provided full-size, multi-function remote, select the source input button to activate the corresponding mode. The status indicator on the soundbar will be solid green in optical mode, orange in coaxial mode and cyan in Aux mode. The indicator lights up for 10 seconds. There’s also a USB port which is marked as “Service” which is most likely used for firmware upgrades/troubleshooting, etc.
To activate the convenient Bluetooth mode, press the Bluetooth button on the remote and pair with your Bluetooth device. I use this connection to Bluetooth pair to my Amazon Echo Dot, as the Dot’s sound is rather low and of low quality. With the Soundcore Infini, I’ve boosted the volume and audio quality exponentially. Now when speaking an Alexa command, the Dot will listen and always send audio to the Soundcore Infini, as they are always connected (solid blue indicator). The Soundbar Infini goes into Standby mode (after 30 minutes of inactivity) when not in use and always connects to the last Bluetooth device. I can also pair with my smartphone, tablet, computers or any Bluetooth supported device. For now, I use it with my Amazon Echo Dot and with my TV’s optical output.
It appears that mounting the soundbar is user friendly with the included wall mounting kit, but I will be using it as shown underneath my TV. The sound is very good at this price point but most likely won’t beat more expensive soundbars made by Klipsch, Polk Audio, JBL, Bose, Yamaha or Sonos. It would be nice if the Soundcore Infini could be Bluetooth paired to a future, optional subwoofer and/or have a SUB out to deliver low frequencies to a sub.
The Soundcore Infini is recommended for those on a budget yet require very good sound from a multitude of audio inputs. Link: https://amzn.to/2RCHBJG
