I am reviewing the soundcore flare.
I guess I’ll start at the beginning. When I opened the shipping box, the first thing I noiticed (and I did actually take notice of it) was how much I loved the packaging. Not only does it look beautiful, but it also is well made to garentee the safety of your product. So I’ll give packaging 5 stars.
So, next I paired it with my phone, which was really easy and fast. I wanted to check the range, so I set it in the main area of the house. I walked over the entire house (upstairs and downstairs) which is about 4000 sq. Feet and it never disconnected. So the Bluetooth connection is another 5 stars.
Next I downloaded the app. It told me that before I could use any features I had to update my speaker. I thought it was convieniant that I could update through Bluetooth through my phone. It took about 15 minutes. After it was updated I played around with the app. I like the different music settings. The only thing I dislike is that the custom sound always sounds bad no matter what. That was disappointing. Next I used the different light displays. They’re fine, and only fine. They need some updating. For instance the sync one isn’t really synced with the music, it’s just random. The other ones work pretty well since they don’t need to sync with the music at all. I like the color choices, some of them are just beautiful. I’ll be generous and give the app 4 stars.
Next I wanted to check out the sound quality and the tonal range of the speaker. The range is amazing! The bass is beautiful and the high notes are melodious! I personally like heavy bass so I always leave bass up on. But I like the fact you can turn it on and off for people who don’t like as much bass. The quality of the speaker is really good for the price you spend. I would say it’s almost as good as the boss soundlink mini. So for sound quality I give 5 stars and for range I give five stars.
Next I wanted to check the volume. And there’s not much to say here. It gets REALLY loud and doesn’t really lose much quality with it. If I use it on max volume it would be completely unreasonable because of how loud it would be. So of course I’m giving this 5 stars.
Now is you did the math I gave this about 4.8 stars.
I would definitely recommend this speaker to anyone. I think this speaker would still be worth the price at 120$. I think that says a lot. The only things that really need to be changed are the app needs to be updated some more and the speakers software needs to be updated to fix the synced light show.
Thanks for reading!
