Firstly your help is appreciated.
The problem.
When I used to long press the play button, my soundcore would usually make a little sound, then connect me to the Google assistant (was just OK google then) but now when press it, I either get a long dial tone like beep, or nothing. (I can turn the dial tone down, as it seems to be related to the Bluetooth call volume)
I would like that little beep back, as it’s hard to know if the soundcore has connected to my Samsung S7.
if I instead have the volume of the “Bluetooth call volume” turned up I just hear the dreaded tone.
Not sure what I’ve done, but it could be related to my installation of Google assistant… Possibly.
Any thoughts?
