Sound Core Pro No Sound
I too have a soundcore pro and it was amazing…used it maybe 10 times…lights come on and even charges fine but absolutely no sound output at all
Did somebody manage to repair their burnt Soundcore Pro?
Is there some way to get a replacement for the “motherboard”/ the circuit?
Could you replace the tps61088 IC(which steps up the voltage for the amplifier, right?), if nothing else is burnt?
Hi @mo-vemma,
Is your Soundcore Pro out of warranty?
Yes it is out of warranty, but I really like it and I want to try to repair it.
In addition to that I noticed that you are offering the Soundcore Pro +, in which you hopefully redesigned the step-voltage-up-section to not burn after a long charging time. Is it maybe possible to get the circuit of the Soundcore Pro + to install it in the Soundcore Pro?
any updates?
