I have not seen any smart battery case aside from this case from apple (the case does look ugly.
What does it means to be a smart battery case? it should become one with your phone. So you can charge it using the same connector, charge the device first then the battery, use battery power before the phone battery. can track the battery of both device.
Anker should make this kind of product and make it look better than apple
