Hi, Hope someone can help. I have just purchased a Anker soundcore from Amazon. The bluetooth works well
but when I connect the soundcore using aux and then plug in the power cable I get very bad static. I have used various aux cables that work fine on other audio systems, but no luck with the new soundcore.
interestingly, when the 3.5mm Aux is connected to an amazon echo dot, without the power cable, it works fine. So it appears to be an issue with the power usb and aux plugged in at the same time. Is this a known issue? is there a fix?
I love the sound quality, but it’s no good if I can’t keep the device on charge and use aux.
Any comments / thoughts / help appreciated
