Our robovac spends forever at the base of our bar stools, how can you stop this happening. It never gets around the kitchen as we have four and I dont want to have to keep removing the bar stools to get the floor done?
Robovac - spends forever cleaning at the base of bar stool
Perhaps it’s trying to tell you something @sandy.mullane
Mine has a “thing” for my surround speaker stands.
It normally gets bored after a while and moves on.
Check that it hasn’t gone into edge mode.
Maybe create some kind of barrier or obstruction to minimise its time in that location.
There are always some spots causing probs.
Best is to remove.
It took me a certain time to get the rooms ready for “Old Willy”
Mary likes that stands.
Old Willy likes a small chair where he is dancing around.
I put that on the desk before I start him!
thank you, I have used both modes neither works. My issue was because it spends so much time even after it ‘gets bored’ it will run out of charge!
thank you. I have moved all sorts of things out already cables especially, but the bar stools are a pain to keep lifting off the floor, the idea is for it to work around anything solid.
Strange one that @sandy.mullane
Maybe try taking a video and send support@eufylife.com for their opinion.
Keep us up to date with your progress.
those stool seem to be very special shaped.
Could you take a photo.
I remember I have a problematic flower stand where I modified the foot so there is no more issue.
