ROAV - HydroClean Review
Have you by chance come across any of the YouTube videos or people pressure washing stuff? I pretty satisfying to watch :joy::joy:
nice review thanks
I would do that, when will it be available in Germany?
i got mine, agree with hose attachment being too close to trigger, but i didnt cut or scratch my hand, mostly because I was careful after reading your review. No problem with power cord storage, but for the hose i made a bigger loop and stored over hook and spray gun handle and it stays put.
My gun was missing logo as well.
Did you notice the 2 holes and also a clip for something right above the tip storage area? The holes look like for storing other longer attachments but not sure what the notch with clip is for…?
EDIT after thinking about it, maybe the holes are for storing the ends of the hose while the rest is looped over the hook to hold hose in place. need to test this theory EDIT
I just did a quick test and I’ll try and write a review this weekend as well. Maybe a side by side of my gas unit but that might be too much of a PITA … But I do want to try my oscillating turbo nozzle from my gas unit on this
Thanks for your response!
There are some options on board that you can use for cable management, I think I was hoping for a retractable power cord or reel for the hoses.
I used a plastic quick connect that I picked up at HD that was very easy to use and made the whole experience a ton easier.
Here’s a few action shots, before/after, writing on concrete, whatever you wanna call it!
Imgur Album - ROAV HydroClean
good pictures :blush:
I’m happy to know the real product experience!
