I recently tested out the white Lumos Smart Bulb by eufy. It’s an awesome and really responsive smart bulb that’s bright and has a really nice warm white color to it. It works with both Alexa and Google Home and is also pretty affordable at $18 and change on Amazon and $33 for a pair on eufy’s website. Be warned that it is larger than a standard light bulb. If you’re considering buying this, make sure it’s going to fit where you want to put it. I made a video review bulb and in it I discuss some of my likes and dislikes on using the bulb over the last month. Aside from the size of it, I really love this bulb and would love to add more to the house! Below are some of the standard specs on it:
Weight: 195 g / 0.43 lbs
Dimensions: 65 x 65 x 140 mm / 2.6 x 2.6 x 5.5 in
FCC ID: 2AB7K-T1011
LED Lifetime: >20,00 hours
Color Temperature: 2700K Tunable White
Lamp Base: E26
Light Output: Max. 800 Lumens
Input Current: 80 mA
Power: 9W
Rated Input Voltage: AC 120 V,60Hz
Thanks for reading and/or watching!
