Review of Anker Roav Dash Cam
Another Anker product that does not disappoint.
The video quality is by far the best I’ve seen, which uses the Sony sensor.
This Roav dash cam has WiFi to transfer your videos for easy use.
I currently have this connected via micro USB and the included Anker cigarette adapter
The included USB cable was long enough to route cleanly, however install would have been a bit easier if the cable was slightly longer. I installed on a 2008 Honda Accord Sedan.
Sorry, for the blurry pictures. My hands shake recently, so I had some trouble with getting good picture. I promise the picture is really as clear as its posted on Anker and Amazon websites.
Thanks for sharing your review! :thumbsup:
Thanks @Ricky_Patel, your review is much appreciated!
