from German:
The Soundcore Flare makes a super robust impression. Due to the clothy surface, he feels great.
The buttons are super easy to use, all functions are shown on it (bass, volume +/-, light modes)
The sound has also convinced me, after all, the most important thing with a speaker This is full and to taste with more bass to have.
I liked that about the app also an EQ is set … as well as the lighting effects.
Whether you need the lighting effects or not is up to you, and you can disable them completely!
I think you are very nice when you put it up appropriately.
I also like the LSP water festival. Although I have not yet tested this, trust the manufacturer here but
And with that comes my only point of criticism: since I would like to use the speaker on the boat (canoe / sail), it would have been really good if there had been an eyelet or the same thing … so I would tie it can! Now I have to come up with something else.
But otherwise I am super happy.
