While recharging the powercore , the LED lamps are blinking but it doesn’t show how much it recharged until its full and turn off . Is it ordinary?
Recharging anker 10050 quick charge 3.0
which adapter do u use?
Correct, as it charges the lights blink on and off until its fully charged. Once removed from the charger you will see the charge state when you press the button
And how much it will take to be recharged while using iphone wall charger
About 11hrs
But sometimes it showes 4 solid lights and when i remove the charger and press the button its showes 7 solid lights … is it ok??
As I mentioned it’s perfectly normal, but try to leave it plugged in until its fully charged.
is the 20000 the only powerbank, which u cab chsrge with 2 cables?
