It’s become apparent to myself, and almost definitely to others, that some people don’t know how to solve a problem.
Now we all know how to reboot our phones/tablets/laptops, and how to reboot your internet connection.
I’ll try to keep this as simple n general as possible.
1, turn off , leave for a minute, and turn back on. (Obvs for products that do)
2, are the connections clean or ok?
It’s amazing how many problems are caused by dirty ports, or bent connectors.
3, try a different…
Cable, charger, device.
It seems simple, but sometimes all you need is to change.
4, should be No1, but check the manual.
Lights/LEDs, and basic troubleshooting is often covered in the manual.
5, updates.
Often a problem occurs due to needing a software update.
Once updated, reboot… Doing this helps out the update in the proper order (probably a tech name for this?)
6, is it meant to?
Is it meant to do what your expecting?
I.E. Some devices don’t do fast charging or need higher specs to.
Obvs this isn’t everything, but it should help with non technical issues.
I’m sure some will add, and I hope so.
