Powertouch 10 cable requirements
I currently have a qi pad in my car arm-rest to charge my phone on the move. The powerport qi 10 which i use on my desk is too large to fit so I think the powertouch 10 would be a better buy for the car but note its usbc. If i purchased a usbc to usb A cable (so that I could plug it into my cars cig point (powerdrive speed 2). Will this charge with fastcharge or do you have to have a usbc to usbc cable and go directly into a wall charger (usbc)?
Thanks
The powerdrive speed 2 does rapidly charge my Pixel, however it depends on what cables you use with it. I go into more detail here - https://www.amazon.co.uk/review/R3RPUTIAMFJAOR/ref=cm_cr_rdp_perm
@Arwen Thx for the information!
@Nick_Thorley You can use the USB-C to USB-A cable came with the wireless charger to enable fast wireless charging with your PowerDrive Speed 2.
