Hello everyone. I bought a PowerPort PD I charger and a PowerCore Slim 10000 battery. I tried to change the battery, but it took almost 2 days and it was only about half charged according to the led lights on the battery.
I reached out to Anker was told that the charger was not compatible with the battery. So they sent me a new charger, a PowerPort II PD. I tried out the new charger and was still having problems getting the battery to charge. It was still taking more than 24 hours to charge and I was only able to get about 75% charge. I also noticed that if I connect my Galaxy S10+ to the PD port on the charger, it would take twice as long or longer than if I used the Anker PowerWave 10W fast wireless charger or the original charger or the PowerPort PD I charger.
I’ve tried using different charging cables and still no luck. From PD on the battery to the phone I have no problems, from the PowerPort PD I to the phone no problem. I ever tried with my wife’s Galaxy S8+ and still the same thing with the PowerPort II PD. I honestly don’t know what is wrong, the cables or the charger.
BTW, I’m not using Anker usb-c to usb-c cables, I’m using Finekeep 10ft usb-c to usb-c right angle fast charge cables I bought from Amazon. And help in this matter would be greatly appreciated, thank you.
