PowerPort Atom 1 compatibility with PowerCore 10000 PD
I’ll probably do the full recharge test soon just to be sure but I think I may be good to go! When I received them I plugged them in and they were at 1 full LED 3 blinking. About 2 hours later they were fully charged. Sounds about right to me!
What device did you use to charge it?
PowerPort 1 PD with 1 PD and 4 PIQ
That is not PowerPort 1 PD… that is PowerPort Speed PD 5, which doesn’t have the incompatibility issue. This is PowerPort PD 1:
My mistake. It doesn’t call it PowerPort Speed PD 5 anywhere on the box or the device itself. Oh well, glad it works though. I’ll see if I can find a friend with a PowerPort 1 PD to test with.
