Received my sample and was real excited to get it put to use. Low and behold, it was awesome. It holds 12 plugs, but only takes up slightly more size than a typical power strip. The various angles of the cords, horizontal and vertical, also make it easy to use.
The angle plug to put into wall was a pleasant surprise and makes that easy to use in the bottom and lays flat, allowing the ability to run against the wall nicely.
I think it could use a USB port, but overall it is a great product. I give it five stars!
