how do i charge this using usbc cable when my samsung charger doesnt have a usbc port?
PowerCore+ 26800
The usbc port is on the battery. So I’m assuming your phone has micro-usb? So you would need a micro-usb to usbc cord. Then you could use PD charging.
Hope you find this helpful
@Fraser_Brown Which PowerCore+ 26800 do you have. There are several models in USB-C, dual Micro USB, and single USB as the charging port to the battery.
