PowerConf Teams Answer Call?
Hi,
I believe the PowerConf now has Teams integration? The mute button seems to work fine - i.e. the status is reflected in the GUI, but Answer/Hang Up doesn’t work.
Does PowerConf support Answer/Hang Up?
Thanks.
@AnkerSupport I’m also interested to know the answer to this question as I’ve noticed the Answer/Hang up button doesn’t work for me, even when the PowerConf is connected to my laptop using the USB cable.
I wonder if a software update could fix that
