Power Up Your Nintendo Switch With Anker's All-New PD PowerCores!
One more question. I see there’s only a usb c for input and a usb-A for IQ output. Can the usb-c not be used for charging a phone while also charging the switch then?
The USB-C port is for both input and output. You will charge your Switch through it. You may also plug in a second device to the USB-A port, and yes, you can use both ports simultaneously.
Ah crap. Amazon Germany doesn’t deliver to the Netherlands. Guess I’ll have to wait.
Hi Joshua
Do you think this one could put the switch at risk in any way?
https://www.bol.com/nl/p/anker-powercore-ii-10000-quick-charge/9200000086926106/?suggestionType=typedsearch&bltgh=uxpSLL6emt7IuumRoUFH9A.1.15.ProductPageUrl
Update: Anker’s PowerCore Nintendo Switch Edition Portable Chargers are now available to pre-order via Amazon US, as well!
No, this will not harm the switch. Although it won’t provide adequat charge either.
thanks for the head up
Hi @Carlos_Moreira,
You may want to check to see if either of these Amazon listings can deliver to the Netherlands. :slight_smile:
Amazon FR
Amazon UK
Not available in Canada, so I picked up the PowerCore 10000 PD and this seems to work fine with my Switch.
Is the supplied USB-C cable got the pull up resistor?
Can someone confirms this will work with the Switch OK?
What happens if I use the USB IQ port with a USB->USB-C cable on the switch, that I have not tried. In case someone in my house accidentally tries that :slight_smile:
Usb c to c cables don’t have, or need 56k ohm pull up resisters. The usb a to c cables do need it if you’re going to be using it for the switch.
Hope that helps. :slight_smile:
Now I’m concern, I just order the following for my Switch and I’m worry it might not work or could damage the Switch
Anker PowerCore+ 26800 PD with 30W Power Delivery Charger, Portable Charger Bundle for MacBook Air / iPad Pro 2018, iPhone XS Max / X / 8, Nexus 5X / 6P, and USB Type-C Laptops with Power Delivery https://www.amazon.com/dp/B01MZ61PRW/ref=cm_sw_r_cp_api_i_H4uVCbC6BWRS8
Anker PowerLine+ C to C 2.0 cable (6ft), High Durability, for USB Type-C Devices Including Samsung Galaxy Note 8 S8 S8+ S9, iPad Pro 2018, Google Pixel, Nexus 6P, Huawei Matebook, MacBook and More https://www.amazon.com/dp/B01LNA0XCU/ref=cm_sw_r_cp_api_i_k5uVCb68323T0
