Possible to review/edit testing plans?
Is it possible to edit a testing plan? I forgot to mentions something that I think would be a great addition.
Also, it would be great to be able to view them, so I can make sure I don’t miss anything as I’m filling out future testing plans or forget to do one if I were to be selected as a tester (fingers crossed…)
Yea I really wish we could see our testing plan. Editing is not an option maybe to prevent cheating
@osnelson You can send your additional ideas as a PM (private message) directly to @Ankerofficial and they will consider it for your selection eligibility
Best of luck👍
They should be able to add it for you if you PM them
Exactly this. I’ve done it a couple of times after submitting and was able to add it on to my original after sending a PM
Care to share your great idea :tongue:
Not that I will steal it :yum:
Lol I’m being sarcastic btw
At least all will have the same testing plan - > “copy & paste” :joy:
