Pixel 3 xl and 65w quick charge 3.0 fast charging issues
Got a new pixel. Used an Anker USB c cables to connect to my power port speed 5 with qc 3.0 . However it does not say " charging rapidly " . Are pixels not supported for fast charge ?
Hi @Arun_Ramamurthy , logically I would say that as long as your phone is fast charge cable and you have a suitable cable, yes it should rapid charge…however I have read that people had issues with the Pixel 2 XL not rapid charging.
I would recommend that you send support@anker.com a email with your issue so they can advise on whether your phone should be supported for fast charge via the PowerPort 5 65W…
From XDA "What you are missing is, that this phone is not compatible with QC standards,
Pixel using USB PD, just like on Nexus 6p and 5x, also like what being used by apple on iPhone X and their new macbook.
If you want quick charge pixel phone. Buy USB PD charger, and USB C to C cable that support PD as well, not QC charger. "
