Hi yamyam, thanks for the suggestion, but range is not an issue for either of my eufycams.
*side note: I have read some of your other posts on Anker community, and you seem pretty unhappy with eufycam. Personally, I appreciate what Anker is doing with Eufy line, and I like it the best of anything in its price point right now. Nothing is perfect - check the competition and you will find plenty of issues, even products that have been on the market for a lot longer or are more expensive. Might want to appreciate Anker for what they have done so far, every once in a while.
Also, limited range is definitely inconvenient - but keep in mind battery life and range are inversely correlated. The longer the range, the worse the battery life. I don’t mind having a little bit less range in exchange for great battery life
