New speakers - Soundcore Boost and Select and Pro
It’s not on walmart.com or Amazon, either… strange!
Did you happen to see SoundCore Pro or Select?
No I did not they had another soundcore I think it was called sport it was a lot thinner than the boost and it cost $69 or $59. I can’t find it at Wal-Mart.com either. I was really surprised to find it in the store. They had 3 on the shelf of the soundcore boost.
If they had pro I would have gotten it instead.
Want a picture of the box with specs on it.
I saw the boost at walmart. The sound. is. awesome. Not just loud, but has a full acoustic resonating power to it
Yes it is very good you didn’t see the other pro or select did you.
Not yet, I imagine that will be the best of the bunch
Yes I own the SoundCore Sport XL. It is $59.
You also have it?
I have the XL. It’s been my apartment sound system for quite a while, sitting at the center of the room
How is the boost compared to it? If you don’t mind me asking, where is your Walmart?
Boost is better than XL imo. Because the XL is supposed to be a travel all-weather speaker, but I just use it stationary at home
The specs are above in link to manual
Surprised they were so forthcoming with a release timeframe…via message…
Just got the pro it has two tweeters makes four speakers total it’s better sound quality than the boost. I have both the boost and the pro now.
They also had the select in stock. As well as the pro, boost and sport xl
these are still not on Anker’s site or searching in Amazon is not finding.
Would like to know your thoughts on battery life, boost claims 12hr and pro 24hr.
Have you tried the pro’s nfc method of connecting?
How much did the pro cost?
