I just recently purchased the Powerwave Stand and Powerwave upgraded pad for my iPhone 11 pro. I was reading through the specs and it says NOT to use the stock Apple wall plug (I know the pro comes with a different plug compared to the others, but I need extra wall plugs). Which wall adapters should I be looking at? I don’t necessarily need the fastest charging…it would be nice though.
Need advice on wall adapter please
To get the fastest wireless charger out of either product you need to plug them into a Quick Charge charger. The charger included with the iPhone 11 Pro is 18W, but uses USB Power Delivery. Similar output, but different tech. Anker’s wireless charging pads are setup to receive Quick Charge, not USB PD.
Take a look at the Anker PowerPort+ 1 with Quick Charge 3.0. It’ll provide fast charging to either wireless pad. And is Anker’s cheapest QC wall charger.
