Nebula Solar portable no sound issue
Thanks for the update.
Chances are you got early access to beta and you helped proved it works, so are helping others who will get the update, giving some of your time to push through the issue.
It would be good if Nebula came here with statement of known issues and future updates.
The firmware version they updated for you what version number did they push out to you to fix the sound issues?
