Bought the Nebula Prizm, Echo if my first ever Nebula device and trying to set it up. Needed some inputs on setting it up at home.
Can someone please guide on following:
- Good options on a tripod stand to mount the Projector
- Bluetooth connection to Home Audio Theater (Vizio System). There is audio output from the projector. Tried with the BT transmitter, did not work (this is on me, need to find some way)
if someone has a tried / tested options, will be helpful.
