I use The Bearded Man Co stuff - I find it really good and has a really wide selection of scents. They do a sampler kit so you can try before fully committing to bigger bottles.
Il have a look online for Fuzzy Duck stuff though
Great picture. Does the remote had these new (bad) controls. (Hold for skip instead of double tap on louder)
Some handsets let you change/modify SMART buttons on headphones/speakers.
So if you got one of the latest top Samsung’s, you could change… Tap tap tap up/down as skip, instead of volume… If that’s the way you prefer it.
