Hello,
I bought the liberty lite earbuds, i have a problem with the right one, its not flashing and not connecting, the left one is flashing, but i cant find them on my bluetooth devices, phone, laptop, do you have any suggestion how it may work?
Mr nadim abou rizk
Try a reset: Place the buds in the case and hold down the button on both simultaneously for about 5~10 sec.
Also do not provide your personal details on the blog such as email.
Also, if this does not work, contact Soundcore Support – service@soundcore.com
1st
Did you remove the film from the back of the buds? (I know at least one model has a film)
2nd,
Remove both from case, out both back, and turn off Bluetooth on device.
3rd,
Turn on BLUETOOTH on device, and remove buds from case … Are they flashing now?
4th,
Make sure they are fully charged.
5th,
I can’t remember how to reset! lol
You should remove your personal information from this post immediately!! @ndalby @TechnicallyWell @AnkerOfficial might be able to help they’re on before the OP…
