Motion sensor
Hello @AnkerOfficial
would be great if there will be a waterproof version from the motion sensor.Sometimes a trigger needs to be fired before the camera detects movement.
Jens
?? Where do you plan on putting it?
Outside on the terrace and in the carport.
Need this option!!!
Hmm maybe you could put inside a plastic housing and see how good that works
Until you get some really rainy, windy weather. Unless the unit is completely sealed, it would get damaged.
True, it may not withstand a heavy rain. Well I’d at least try, or maybe find a spot where it is covered and shielded from the elements
