I think anker has great speakers, but those speakers have a pretty low sound, even if it is ok for home use. Those should have more powerful sound. What do you think?
More powerful speakers
Take a look at the RAVE series.
They have some speaker that are louder than others. The ace series as a small sound which is ideal for on the go (clipped to a backpack or something) The flare and flare+ are pretty loud home speakers, and also have decent portability for it you go to a barbecue or something. The rave series is super loud, and is great for booming parties.
It’s just all about which one you buy
Motion+ is good for “riot”,
