A couple new products have recently appeared on Mynt’s Amazon storefront.
Wearable Heating Wrap
Key Details
- Use Anywhere: A USB 2.0 connection means you can plug-in, and warm up practically anywhere – from the office, to the great outdoors.
- Intuitive Interface: A single button interface allows you to effortlessly power-on and cycle through 3 color-coded temperatures.
- Desirable Design: Made from micro-velvet, for a finish that’s soft to skin. Washable, for long-term hygienic performance.
- Wear Discreetly: Wear under a coat, or scarf for discrete heat – anytime, anywhere. Adjustable clasp buttons fit practically anyone.
- What You Get: Wearable Heating Wrap, Carry / Washing Bag, USB Extension Cable (1m), Owner’s Manual, 12 month warranty & fan favourite support.
Price: Regularly $25, Currently Save $3 with Coupon
Amazon Link: https://amazon.com/dp/B0774J7P6T
Heating Cushion
Key Details
- Warm Up Anywhere: A lightweight and portable design is perfect for warming up anywhere – from the car, to the office, to the great outdoors.
- Utility USB: A USB connector and 1m extension cable means you can plug into a computer, wall charger, or even a power bank.
- Simple Controls: A single button controls everything. Hold to turn on / off, and press to cycle through 3 color-coded heat settings.
- Comfort Build: A soft and washable dual micro-velvet design feels good against skin and stays completely clean.
- What You Get: Heating Cushion, Carry / Washing Bag, USB Extension Cable (1m), Owner’s Manual, 12 month warranty & fan favourite support.
Amazon link: https://www.amazon.com/Mynt-Heating-USB-Connector-Cushioned-Micro-Velvet/dp/B0774RL3JM
Are you interested in any of these new releases from Mynt? Let us know!
