Lost my USB-C cable - need to find correct replacement to charge "Anker PowerCore+ 26800 with USB-C PD" (battery)
Hi,
I own a “Anker PowerCore+ 26800 with USB-C PD” (battery) and used to charge it with a “PowerPort+ 5 USB-C” (charger).
I am mainly using the battery to charge my Huawei Mate 9 on the go.
Recently, I lost the USB-C to USB-C cable that came with either the Battery or the Charger.
I since purchased a new cable on amazon (ICZI USB C to USB C) - seems to be USB 2.0 Type-C.
This works to charge my Mate9 with full speed from both the charger and the battery - but it does not work to charge the battery.
Where can I find a replacement for the correct cable to charge my battery again? What specs does it need to have?
Thanks!
lmh
