Issues bluetooth connecting macbook to Soundcore trance go
I can’t connect my soundcore Trance go speaker to my 2020 macbook. it connects to my iphone without any issue but for some reason it doesn’t apppear in macbook bluetooth when searching. Anyone else experienced this issue? My macbook can see and connect to other bluetooth devices, just not the soundcore speaker
You should turn off the phone, or better remove the speaker from the bt-list of that phone and try a connecting to that MB.
If it’s paired to your phone then your laptop won’t pick up the speaker, you also have to put the speaker into pairing mode by pressing the Bluetooth button in order for your laptop to pick it up
