Issue with Soundcore Liberty Air connected to MacBook
Yes. I bought mine in March 2019 and I could only use it properly with my cell phone. Lots of installs and updates however it only worked with my Dell Laptop after I turned off my Microsoft BT mouse. It seemed a problem with the mouse, since I could use BraView BT keyboard together … working ok. But everything working together, only with another BT headphone…
Just bought the Soundcore Liberty Air 2 Pro. Every few minutes the sound cuts out for about half a second. Did ALL of the above and more:
Reset BT module
SMC and PRAM reset
no other BT devices connected
no other BT activated devices near
deleted the Bluetooth files
reset the liberty air 2 pro
fiddled with the com.apple.BluetoothAudioAgent settings
reset everything again. Problem remains.
tried my 20€ Xiaomi Airdots… they work fine.
Any more ideas?
There is a special forum from soundcore you should ask there.
Many users of those earbuds.
https://community.soundcore.com/
There are those issues with macbooks described as far I remember.
I am sure you find some help there.
Hi Chiquinho,
thanks for the hint, I created another thread there. Hope to find somebody who can help there. I searched the forum, but the only similar problem I found was in this one: Issue with Soundcore Liberty Air connected to MacBook
As mentioned: I tried everything they did… but no success so far.
EDIT: oh, it’s THIS thread ^^ thought I was in another one ^^
Good luck.
Otherwise a email to the soundcore support could be helpful
But I am sure they got no better ideas than the regulars have.:grin:
Issue resolved! It’s a bug of MacOs monterey:
to solve: go to system preferences -> Sharing -> deselect AirPlayReceiver
Long time no see Nappa
Ersatzkater, this worked beautifully for me, and it’s a 5-second fix. Thank you!
Vegeta! Long time indeed since you… ahem… terminated our professional partnership. No hard feelings. Did you dye your hair? You are rocking this blue! Really brings out the eyes!
Happy the fix helped somebody :slight_smile:
Lol thanks Nappa :rofl:
