Is the PowerCore+ & Power Port w/Wall Charger Compatible w/Google Pixel 2 XL
Provided you use the correct cable yes, they work with the pixel 2 XL. The power Iq should adjust to whatever your phones needs are.
Yes if you use the right cable.
