I have both a powerport II and powerport Elite. My power port II is now two years old and has been everywhere and has takin a pounding and still is going. I do want to replace it for my wife and a smaller unit would be nice because the plug on her side of the bed is crowded a little which is why the plugs have been bent. The power port elite I keep at work and though it is larger it works exceptionally well and has been going for over a year now. I’d love to try a smaller one out if that becomes available, otherwise I’ll just buy one.
Is Smaller, Better? Tell Us Your Thoughts!
JoshuaD11. I just looked at the earliest Reviews on Amazon on the power port II and they go back to 2016. It may not be exactly 48 months but the one I got was acquired through the power user program. There are no dates on the power user log and the review links are useless, but I still claim that I’ve had this device for a significant amount of time and it is still working to this day just fine. It has been constantly used and abused not only in my previous job and residence that I moved out of in early 2017, but has traveled with me before that on at half a dozen road trips and a cross country business trip I took in late 2016.
I am not arguing that it is not a durable, long-lasting product. What I am saying is that, unless you received the product as a part of the beta testing program, you couldn’t have had the PowerPort II for that long. Oldest review on Amazon is from October of 2017.
@joshuad11 you do realize that review mentioned he has the new version and the older version, so the one you linked to is for the new version not the old one
No, I do not realize that. Where?
Yes, so the review is for the correct product as @ARTHUR_BRIAN_MOTT is saying PowerPort II (the newer one), not his PowerPort Elite 2.
To me, the size does not matter too much as it’s a very minimal change. I always prioritize functionality over convenience. I often use bigger speakers and bigger portable chargers with my phone. I do think I have an unpopular opinion though but I would choose C. I also don’t like spending more money then I have to.
As odd as it may sound, for me smaller is usually bigger.
I need a lot of ports. So why buy 7 1 port chargers instead of just one big one.
While I am at it: Anker plz make all ports on all your chargers be able to simultaneously output over the quite outdated 2A.
3A is the very minimum, but I need 4A.
Smaller is better, just dont let it overheat
Do not forget there are physical limits.
Remember the Samsung phone.
Small and Portable
Samsung phone that made explosive entry into the market not so long ago?
I agree with you!
Compromises with the cooling and performance must not be made just for the slimer look.
Charger must be able to stay connected and under load for days without catching fire or exploding
Hey Samsungs phone only got national attention because they recalled them twice in their own accord to prevent issues. When in reality, Apple has also had its share of devices explode and catch in fire too. It’s funny how everyone is quick to mention the exploding note 7 but forgoe all the other phones that have done the same
The reason samsung gets all of the attention is mainly because their issues revolved around a terrible design that year. The battery they needed, paired with the size requirements resulted in them having as battery built in a way that was asking for a meltdown. Apple and most others had issues that typically fell around a faulty component, or someone charging it in an incorrect way (under a pillow, on top of a carpeted area etc.) My old G4 was the closest issue to a terrible design, where they stacked a processor over the battery contacts and another high heat item without proper heat sinking (this led to the infamous boot loop errors). Samsung’s issue was and a bigger issue purely based on the fact it could happen at any time, any place for almost any reason. That is not a very common issue for most phones.
I will vote for A (with folding prongs of course)
We will definitely consider the safety issue as the priority.
Yes it is also a question of cooling the processor.
But of battery design as well.
Sometimes “the smaller the better” will NOT
lead to a perfect result.
Samsung has been doing g mobile phones since the 90s.
Due to an error in the set up of the note 7 battery n charging, they had to stop the whole thing, and recall.
Some chose to wait for the note 8, while others could have the current/coming galaxy. From what I heard over the fkup their CS actually worked this time… Customer service is definitely a huge stumbling block of Samsung.
Yes, they took a huge hit globally, but they’re coming back and like before note 7 they will be stronger than apple again.
However, they are still the best Android handset out there. Many copy but none replicate!
