Is Experience level VIP possible in our lifetime?
Thanks for everyone’s kind suggestions, we will consider all your concerns and make effort to create a new, balanced, and reasonable points system ASAP, please be patient!:blush:
Hey @AnkerOfficial, I’ve been a user and member since 2013 and had racked up over 10k Anker bucks over the years. I was ranked #2 in terms of points but they have never been put back into my account since the migration to the new system.
I would love if you can fix that so I can be restored to my right level :slight_smile:
Hi @Fire_and_Ice, I check your personal profile, and I found that you posted 4 times in totally since last year on September, so I would suggest you to be more active in the community, so as to reach more higher level you want.:hugging:
Can you check the old Anker points system that gave points not based on posting but gave points on checking in daily?
Yes, I checked the original points system, it will also require you to earn points by active community behaviors. [Event Ended] Power Station Grand Opening: Points Win Prizes
The experience points now are relevant to your level, by your previous community behaviors, you receive nearly 150 points, so you are in LV2 now. If you want to reach LV3, you will need 300 points.:grin:
Just realized that @AnkerOfficial has updated the way you earn points. Check it out here:
https://community.anker.com/power_draw/bucks
Thanks again! Looks much better than before.
So now I’m seeing
So a maximally participating community member:
  • Bucks: earns 5x2+2x10+1x5= 10+20+5 = 35 bucks per day. Higher if you can get a sticky.
  • Experience: earns 10x2 + 5x10 + 5x5 + 2x5 + 2x5 = 20+50+25+10+10= 115 experience points, higher if you get a sticky.
So a VIP Lv21 240000 is 240000/115 = 2087 days = 5.7 years. Less if you get stickies.
I may have made an error, happy for someone else to check and correct me.
Yep an executive member (which appears to have similar benefits) in half that time, so 2.85 years.
The numbers match up with what @AnkerOfficial suggested on messages. 5.7 years is not that bad when compared to some forums and being at the levels does not guarantee all the perks mentioned or at what frequency you would get them :slight_smile:
This is just outrageous lol. 11 years to become a top dog if you do everything right ever single day. There must be a better way to get points :joy:.
Didn’t read the updates until now. Seems like the new point system is a better way to gain them for sure. I still think I won’t ever make it to even 15 though.
Go to college.
Work.
Get a job.
Spend money on things rather than wait for free.
You did ask.
Lol yup. Or I could just win some stuff eight the powerdraw.
Will be interesting to see what happens when the first member hits level 21 (which is likely to be @joshuad11 or @nigelhealy based on current level patterns) and the ensuring fallout when the promises expected don’t line up with their reality…
I’m not concerned. Anker has done a fantastic job at keeping their promises!
Anker always does, what other electronic company do you see having giveaways and programs like power user?
Well, I can think of at least four others…
Which ones? Anker is the only one I’ve come across.
It’s imposible
Is there a way to check your own experience points? I can see my level and my PowerBucks, but I couldn’t find a way to check my exp points.
