What happens when I plug in the supplied charging cable to a phone charger (e.g. Samsung), would it be too powerful to charge the Soundbuds? Would any damage occur? I read that it is advised to use wall charger or USB port, but there is no way to be sure those are significantly less powerful than a phone charger?
Is charging via phone charger bad for Soundbuds Slim?
You have no need to worry about your Samsung wall charger. My only tip is when charging from a power bank if the power bank capacity (mah) is too large sometimes you won’t get a full charge because larger powerbanks have a higher voltage cutoff. For charging on the go I recommend the Anker PowerCore+ mini 3350mAh
https://smile.amazon.com/Anker-PowerCore-Lipstick-Sized-Generation-Batteries/dp/B005NF5NTK/ref=sr_1_1?ie=UTF8&qid=1526007461&sr=8-1&keywords=Powercore+3350&dpID=31XHQIF%2BtlL&preST=SY300_QL70&dpSrc=srch
He mentioned the Samsung supplied WALL charger, not a Powerbank… I’m pretty sure
Good eye, fixed.
