Does anyone know if this has a sd slot? For example, I use Kodi on my fire tv via micro sd, but I doubt the built in version here will have enough storage?
Introducing Nebula Soundbar Fire TV Edition!
@Chris_Richards2
It supports 4k so it will most likely run Kodi smoothly.
I’m thinking no on the SD card slot Maybe USB-A
Edit
So it has a USB port but it say “only for updating”
most of these speakers have USB for service only, meaning to upgrade the firmware etc., they cannot be used even for playing audio files.
Not tried one, but this is what I think.
I think Uma Thurman would do naughty naked things with me if I ever met her. I’ve never tried, but this is what I think.
you can get MicroSd Card to USB adapter and use it with the Nebula soundbar, .
I have a different brand soundbar, and the USB port can be used to play music
Ehhh… yes it all fits together but does the USB port on the sound bar communicate with the built in fire TV.
I’m curious does the USB port on this bar say “Only for updating” something similar?
There is no specific wording on the soundbar, but the USB input plays only .wav file (yeah… i hate this part of .wav file )
