I just bought Anker PowerCore 10000 PD. I fully charged it then plugged it into my iPad Pro with a USB measurement tool. After a while, the battery died after ~4000mAh. Is this normal?
Inaccurate mAh specs?
Nevermind. I googled up some answers. There is some energy loss happening when charging at higher voltages.
While you are correct, it doesn’t seem that it would be this drastic. Idk
Well done @movingincircles
Self help is the best help … most of the time the answer is on web and lot of sites have the details available.
Also at times, checking with Anker Support support@anker.com may yield answers during business hours / days.
Good point @movingincircles wonder how much energy loss would be there even if charging at higher voltages
