I need help learning how to charge my new Anker SoundBuds Sport
They sound good but I can’t figure out how to move the USB icon aside to access the mini USB port.
How do I move the rubber icon aside to access the mini usb ???
Thanks in advance.
4 mins 48 sec in you see them open it.
It looks easy.
Thank You , so much, Nigel - I just kind of “peeled” the rubber back starting from the top and moved toward the bottom and it just came off exposing the micro USB charging port.
:relaxed:
Did your problem has been solved?:blush:
