I make a Mistake about the Firmware, I was updated the firmware for Flare +, so how to get back or downgrade or reset the software to latest version?
How to reverse the software firmware soundcore Flare
What happens if you do an update with the correct update?
I wonder if there is a way to downgrade the firmware version
If the old one is still available it could be done.
But often the OS dont allow that.
This is great with LINUX.
It con be done easily.
They keep the older kernel-versions.
If something doesn’t work with the new one you can downgrade by changing the kernel.
That’s all.
But I never needed it.
